180 tstat and heat
TexasRammer
College Station, TX
anyone with a 180 tstat notice a problem with their heat inside the truck? im still having problems with my heat even after taking apart my hvac system and replacing the heater core. My truck gets up to about 193 degrees so its warmed up but the heat coming out the vents is just somewhat warm.... im starting to get really pissed with this thing. will the like 20 degree difference with a 180 tstat make that much of a difference? I felt the hoses leading to the core and noticed one was burning hot and the other was just somewhat hot, now I know it will lose heat passing through the core but possibly the new heater core got clogged again? Im completely stumped now... what do yall think?
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I always noticed that it took longer for the heater to get up to full heat with the 180 stat, but it was always plenty warm enough.
TexasRammer
TexasRammer
College Station, TX
Did you burp the system really well?
.... how did I forget that:Stupid Me:.... pretty sure I didnt, but I dont think that would make that much of a difference. Ill do that later
yeah it seems to take a while but even at normal temps its not that warm. I did the core swap last summer and about a month ago when I used the heat it seemed to work fine and got pretty warm in the cab but it wasnt that cold out so I didnt use it for long but it seemed like it was warmer then it is now
SmokedRam
Zephyrhills, Florida
You'd be surprised what air trapped in your cooling system can do...probably have an air pocket in the heater core.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
My 170* warms up just as fast as my stock system did far as the air temp, maybe I lucked out on that. The 180* was the same way, im running Stant's also, not the Jet.
bronx79
Montana
Slightly off topic but what does the 180 deg tstat do for you anyway? whats the stock temp tstat?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
The colder T-stat helps richen up the A/F and keep cylinder temps down. The Hemi's run alill over 200 stock and cooling it down helps when you make a wide open pull as the motor makes more heat through the pull. You will see alot of guys running headers do that to keep the A/F closer to what it needs to be because the headers will lean out the A/F causing issues. You will also help prevent knock and be able to be safer all the way around.
bronx79
Montana
Oh that's great to know because I run long tube headers and would love to know if mine had ever been changed to a 180.... Sounds like my truck would run better with that mod and its cheap! Thank you for the info!
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Its a fairly quick swap you can run a Jet or buy a Stant and run that. It the Jet will drop right in an Moe's sells them, the Stant you should be able to find at a local auto parts store but may require a quick trim.
bronx79
Montana
When you say "drop in" does that mean I don't have to drain fluids or at least all of it? And I not sure what you mean by start? Love the MOE's website! I will for sure buy from Matt. Thank you
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Stant is a name brand like Jet is. You will lose some fluid, if you have never changed your rad fluid this would be the time to go ahead and swap it out. You will just need a large pan to catch all of it and new Mopar coolant to go back in with distilled water. Mopar is going to need to be cut, they do not offer a premix.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
True, there is also a Cat Machinery aintifreeze that has HOAT
