1960 International R-190 4X4 build. DT360 / Eaton 6 speed / NP271 / F550 Frame
DILLIGAF
DILLIGAF
Canadian Forces
Canada
Ill give it an extra 1/2" when I set the bumpstop height with the airbags :smoke2:
I could also add another leaf in the pack , but that sounds retarded and that's what a normal sane person would do. ;)
Yardbird
Western NC
Or, you could cut out a 1/2" or 3/4" spacer and mount it to the bottom of the leaf. Only cost and trouble is cutting it and a new center bolt.
I've done that a few times.
You "sane" now that made me laugh,there's nothing father from the truth :Big Laugh: :Big Laugh: :Big Laugh:
DILLIGAF
DILLIGAF
Canadian Forces
Canada
I think I will copy this design for my frame side track bar bracket today :Big Laugh:
Also will need to modify the one thats on the Dana60
Havent used the plasma table in like 6 weeks. Thats some bullsh!t I need to rectify...lol...
TMR customs is awesome, its acutally only 76$ Cdn for that piece. Not even worth building it at that price. But Like everything else on my build, it wouldn't fit without any modification on my truck.:rolleyes:
And I also found a decently priced Gen 3 Dodge NP271 T-case shift lever on eBay this morning, The ford one was engineered by ******* morons.
DILLIGAF
DILLIGAF
Canadian Forces
Canada
Cant belive I found this, Time to make it in CAD and get it ready to cut on the plasma table.
DILLIGAF
DILLIGAF
Canadian Forces
Canada
Designed a simple Power Steering cooler bracket :cool: , My Howe Performance bypass also shipped yesterday :favorites37:
DILLIGAF
DILLIGAF
Canadian Forces
Canada
Today was a good day.
F550 hydrobost installed. Ordered a bunch of fittings and hose to hook everything up.
Shock is pretty close to the bag, I'll cut some 1/4 spacers on the plasma to move out the mounting bracket. Will also cut top protectors for the bags. As the included ones are absolute dog **** that just collect garbage and rust out.
I did install some Air lift cradles as well. To make up the difference so the internal bump stops hit.
The T-Case adapter also showed up. :peace: :smoke2: :anitoof:
DILLIGAF
DILLIGAF
Canadian Forces
Canada
Got my buddy to make my high pressure PS line. A 4000psi hose should be good enough ;)
DILLIGAF
DILLIGAF
Canadian Forces
Canada
Dont worry the low pressure side will all be AN fittings ;) Those morons at Ford sure like making everything more complicated with all different thread pitch on the Hydroboost and PS box. Must be why they like to eat **** so much.
But I wanted some good hose in that area due to the fact that I cant secure it all properly. Will also wrap it with hydraulic hose protector. :cool:
The price of fittings has sky rocketed in the last 1/2 dozen years or so, :rolleyes:
[Edited by moderator to remove political content]
DILLIGAF
DILLIGAF
Canadian Forces
Canada
Sounds like work, no thanks :smoke2: I got to install this next anyways ;)
This one should have at least a foot of drop so my flat deck can hit the ground.
DILLIGAF
DILLIGAF
Canadian Forces
Canada
Waiting on my Amazon order so I put the bumper on and tested the bags :peace:
I'm putting on 40s so that bumper will be 4" off the ground at full drop. It's the price to pay to keep it 4x4 . But having a Dana60 high pinion up front is cooler ;)
No members online now.
bradstephens25
