Do those air brake slack adjusters (they look like ones off S cam air brakes) allow you to position the cab at different angles?
, I saw this video a while back and said to myself if it works with an engine it would work on a Cab. https://www.youtube.com/watch?v=vDEpVvYgEiI
, they are only 35$ for the Adjuster and 38$ for the S Cam.ThanksYup, I built a man size rotisserie, I saw this video a while back and said to myself if it works with an engine it would work on a Cab. https://www.youtube.com/watch?v=vDEpVvYgEiI
I will be adding one to my engine stand as well, they are only 35$ for the Adjuster and 38$ for the S Cam.
Flatheads were notorious for going through water pumpsChanging the water pumps on my 46 today they orinals ones only lasted 33xxx miles.
How much room does that leave you to get at the bellhousing bolts? Looks good IanPretty happy how small the doghouse turned out.
Should be able to get the rest done tomorrow. The hard part is done.
What about making the top panel a bolt in panel using tabsJust enough that Ill be swearing at the Co******** who built it when I got to get at them.![]()
