2" level & 2" hubcentric adapters on 315's
Tyy1907
4.7 magnum
Hey guys I'm wondering if someone can chime in on this one I haven't found anything searching on it specifically. I've got an 03 1500 4x4 and I've been running 2" hubcentric lug centric wheel adapters for close to 50k and had no issues. I know that guys run 315's on the 02-05's with the 2" torsion level with little to no rubbing. I'll probly go with the bfg all terrain ta ko2's as they fit on my stock 17's. Since I've got the spacers will my wheels "swing"more and rub when turning?
usaf2006
North Carolina
It's possible. On my 06 4x4 it seems as I may be able to run 315s without anthing, with only slight rub on the front outer corner of the fenders. I'll have my tires for at least another 5k, so I won't know until then. Where'd you get your spacers? I've been thinking about getting a set. If I get spacers, I'll probably just get 35/12.5s for the extra street cred.. I mean tire width. If I could find a set of cheap used 20" rims, I'd go with 37s :crazy: - Everyone says they won't fit but I'll make it muahahaha
T
Tyy1907
4.7 magnum
EBay
I just searched for hubcentric and the right bolt pattern, thread etc. These ones are Billet aluminum. Blue loctited and torqued, drew paint lines on the nut and studs for easy checking of movement - they haven't moved at all.
usaf2006
North Carolina
Nice. I'm thinking about the same. Didn't want to double the price for "brand name" for the same thing.
T
Tyy1907
4.7 magnum
Also I bought an intake off a guy who ran 2" spacers on his ram 1500 and he put like 100,000 km on his with them never had a problem sold his truck with them still on. He bought his off eBay as well
T
Tyy1907
4.7 magnum
Nothing a heat gun wouldn't handle............hopefully
T
Tyy1907
4.7 magnum
Well in case anyone's interested I've got the 315 ko2's on with the 2" torsion lift and also added 2" lift shackles for the back. Slightly higher ass end gives it a kind of "stock" look yet it's lifted. It pretty much raised the back the full 2" also. As far as rubbing there's no real rubbing going on at all. Just if I'm cranked and going I reverse it rubs a bit. It's so minor though trimming hasn't crossed my mind.
