2003 Dodge Ram Electrical Issues
VIC HIX
Bloomingdale Ohio
2003 Dodge Ram 1500
ST/STL 4x4
V#1D7HU18DX3J633503,
Dodge Magnum
5.7 L Hemi Vin:D,
Problem: vehicle would start run perfect, and just like you turned the ignition switch off engine dies, may or may not crank, or crank and die, or crank and run a for 5 minutes and die, the fuse box, a replacement ECU was Vin programmed, the FCM was Vin programmed, and the TCM was also replaced! and now the vehicle is throwing Code P0633, a SKIM Code issue "this code is new, never showed up in the past, shop is scratching their heads, so I got to search for answers!! Any Ideas, truck has been in shop since 11/10/25 Please and Thank You!!
tron67j
Maryland
V
VIC HIX
Bloomingdale Ohio
2003 Dodge Ram 1500
ST/STL 4x4
Dodge Magnum
5.7 L Hemi Vin:D,
pgoodwin79
Quinton,AL
Has the fuel pressure been monitored when it will crank?
Fuel pump getting hot and cutting off or fuel pump relay getting hot and not contacting correctly
