2004 Ram Ambient Senor Cable Routing
RuDog2004
California
4.7L
Greeting RAM owners, I received a P0071 code that led me to Ambient Temperature At Senor. When I went to check the senor, I found the cable was not connected. I was not able to locate where that cable should be connected to. I search for a wiring diagram, found lots of them, but know showed what I need. I'm hoping that someone would do the honors and take a photo of where the Ambient Senor is connected to, thanks in advance RAM Family
tron67j
Maryland
The sensor should be on the driver side of the radiator, when you open the hood look right on the side of the radiator near the upper half of it. If not there it might have fallen off and the broke apart, or someone took it off and never replaced. You can reach out to Benny in the vendor section, All Mopar Parts and he can verify part number.
