2006 RAM 1500 no high beams, no low beams, bulbs are good. Tipm or headlight switch or something else?
EDWARDINCONN
Connecticut
I am baffled at this stupid Tipmsetup that I lucked out getting in this new to me truck. Is there a relay or fuse that I need to look for or am I going to get ***** for a new tipm and programming? Is there a way to rig up a relay system to the light switch and avoid replacing the tipm if it is defective? Thanks guys. I'm sure somebody has run into this before.
HarryS
Air Force
Clovis NM
without a wiring diagram, it'd be tough to determine the issue. Check fuses in the TIPM, owners manual will tell what is what. If you have a meter, you can check at the HL switch for power and ground.
ManBOOYA
