2007 Dodge Ram 2500 tight front squeek
Iamthebarbarian
Oregon
hello I have a 2007 Dodge Ram 2500
The driver side front end has a squeak. The faster I go the louder it gets. It hear it the most between 60-70 mph. Any ideas what it might be. Or has anyone else dealt with this. I have done some reading and it looks like it is a wheel bearing.
fastf
Georgia
2005 Ram 1500 Quad Cab SLT Thunder road
First off how many miles are on your truck? Go to the front and push down and see if it sqeaks when it rebounds the idea comes to mind is ball joints there are no grease fittings to grease the front end now the second thing comes to mind is a wheel bearing going bad .Jack that side up and spin the wheel and try to wiggle it from side to side and up and down if it squeaks or you have any play get that bearing replaced soon .There was a member the front wheel came off from the bearing going bad he is one lucky person.I hope this will give some idea to look when these trucks get above the 100 thousand mark look for to do frontend work i had to do mine myself last year.
fastf
Georgia
Yes that could be it too.I would rather be safe than sorry check everything real well.Remember other people ride in that truck too and you want your ride safe too.
I
Iamthebarbarian
Oregon
It has 65K miles on it. I’ll go push down on it see if it makes any noise and then jack it up and see what it dose. Thank you. I’ll let you know what I find out. I really appreciate it.
