2009 5.7 Won’t Turn over
RAMTRPR
"Enjoy The Little Things"
Brentwood, CA
I have replaced Starter
Checked Fuel Pump fuse
Checked ignition fuse
Tried putting in neutral
Check trans position switch
Took negative cable off
Pulled PCM fuse
I get the red lightning bolt and then it goes away. No CEL. No codes.
Any suggestions? I’ll try to get a video up as well.
2009 QCSB 4WD - Not Stock [emoji41]
RAMTRPR
RAMTRPR
Brentwood, CA
HemiPower36
CA
2014 Ram 1500 Laramie 4x4 3.92 8-speed
Hate to be a jack ass, but you did not mention your battery. Maybe that’s that issue. :)
RAMTRPR
RAMTRPR
Brentwood, CA
Battery is a month old and has a great charge :(
you need to find the wire that runs from the TIPM to the starter and jump that to see if the engine cranks.
My neighbor's 2009 starter went bad and also fried the TIPM.
RAMTRPR
RAMTRPR
Brentwood, CA
I do have the neutral light on under the 4wd selector and it won’t go off. Could it be something with the trans?
Trans is brand new as well.
RAMTRPR
RAMTRPR
Brentwood, CA
Just took a video from under the rear of the truck. I don’t think the fuel pump is coming on.
How hard is it to test to see if it’s the pump or the relay?
Rampant
NJ
392 Hemi
Unfortunately, you're going to need a scan tool with live data capability or start plugging gauges inline and probing/jumping wires manually. I wouldn't recommend the latter if you don't know what you're doing. In the video, your battery gauge shows about ~10v. If that's not the true battery voltage, start looking between there. Could very well be a battery cable and/or ground. It won't attempt to start if it thinks your battery voltage is that low.
Note: When not running with key on, the battery gauge reads battery voltage. When running, that gauge reads alternator output.
RAMTRPR
RAMTRPR
Brentwood, CA
I will have to check the grounds. I did test the fuel pump itself and it is not coming on at all :( I think the FP is bad.
Have to drop the tank for that which is going to suck. I bypassed the FP relay and powered pump directly and got nothing.
RAMTRPR
RAMTRPR
Brentwood, CA
Battery charger said battery was an 12.0. I am charging it but not sure it will help.
Checked ground for starter as well as the other important grounds. All looks good and power is getting to the fuel pump relay too. You can hear it click but then fuel pump does nothing.
225k on a single fuel pump I guess is pretty good right?
RAMTRPR
RAMTRPR
Brentwood, CA
BTW this happened after getting on the freeway quickly if you will and then got off a couple exits later. Pulled away from the stoplight slowly and then basically ran out of gas (still had full electrical) and truck died then would not start again. Sounds like fuel pump to me :(
RammerHarder
PA
You might be right! How many miles are on this truck (?) Has the fuel pump and relay ever been replaced before?
Unattach the fuse box (the one under the hood) and make sure a rodent didn`t chew up your wiring under the fuse box.
That happened to my last truck with the same symptoms you`re describing. Under the fuse box is a nice home for rodents.
RAMTRPR
RAMTRPR
Brentwood, CA
I’ll check the fuse box in the Morning and the truck has 225k+ on her with Original fuel pump.
RammerHarder
PA
Yeah i think i would be leaning towards the idea that its likely the fuel pump. Let us know how you make out.
PS... i thru the thoughts of rodent invasion because that happened to me. I surely hope thats NOT the case with yours.
daveray9
225k miles... damn. I got a 2012 with 70k and I thought that was a lot.
Sent from my SM-G920V using Tapatalk
RAMTRPR
RAMTRPR
Brentwood, CA
Mine has the extra 4.5gallon tank as well because it was a fleet truck at one time. It is at the shop $659 out the door for new pump assembly and they are checking the extra tank and cleaning everything up as well. Local shop FTW.
I pick it up tomorrow. I’ll report when it’s done.
RAMTRPR
RAMTRPR
Brentwood, CA
Fuel pump replaced and all is well. At least my diagnosis was correct. Had a shop do it. $659 with tax and warranty.
RammerHarder
PA
With tax & warranty...??? Whats the warranty your describing (???)
So how much was out of your pocket...??? $659 sounds kind of high to me. (?)
RammerHarder
PA
DANGGGGGGG, that pump dont owe you nuffin bro! Thats a long *** time for a pump in my opinion!
dakota18
