PeterGreenawalt
My 2010 Ram 1500 4.7L Duramax has in intermittant issue where while driving (or sometimes idling in park) the ESC OFF icon and the ESP Basic/Serv 4wd lights will come on and the shift column will lock if you put it in park. Shutting off the ignition to reboot the ECM clears the error and unlocks the shifter (until the bext occurance ) No check engine light ever comes on and OBD scanner does not detect the issue Any help would be greatly appreciated. Thanks!
