2011 Ram dead battery put in neutral - tow braking assist in place of lever
BarbaryCoastW
SF
I'm trying to put my 2011 Ram into neutral with a dead battery. I know there is supposed to be a manual lever above the emergency release about the parking break but my model has a towing break assist in that spot and I can't find any such lever. As you can see I pried it off to look.
This a column shifter
Can anyone assist? Thanks
SitKneelBend
St. Louis
3.6 Pentastar
That location is for the 8 speed electronic transmissions. Do you have a column or console shifter?
SitKneelBend
St. Louis
3.6 Pentastar
He mentioned column shifter
Thanks, I missed that. Correct me if I'm wrong but with the column shifter their isn't anything special to get to neutral besides just stepping on the brake and shifting right?
audiophile
5.7L
I think the key has to be in the "on" position as well.......
i don't know if this is the way it works on the 2011 model
but this works on the 2014 HD Rams with column shift
press E Brake
press brake pedal
move tilt column fully up
Under the column you will find 2 or 3 holes
the hole closest to the ignition switch has a pin in it, that pin must be pushed up a little
The guy in the video had a 6" screwdriver, maybe a Philips ?
Wheatboy
Is there not a Dial/Slider under the radio console that does what you're asking (ie. 4x4 neutral for towing)?
