2012 Ram 2500 Diesel Brake Calpier Slide Pin SEIZED
lukebz
Sonoma
I'm in the midst of a brake job, and trying to re-install the caliper but have come across something that doesn't seem right. The top slide pin does NOT slide or rotate. There is NO movement. I've never seen this before and don't know what my next step should be.
I've tried to use a wrench to turn, hit it with a hammer to try and dislodge it, and the caliper will not mat up to it. The whole purpose of these is to be loose and this one is certainly not.
Dead in the water. Send help.
Tach_tech
5.7L HEMI
Spit and pressure!!!
Put the bracket in a vice, beat it, turn it,lube it, repeat. Could try a bit of heat as well. At this point it’s already messed up, you’re not gonna make it worse, so don’t make love to it, f*ck it. If all else fails you may have to end up replacing the bracket.
lukebz
lukebz
Sonoma
Any other opinions, suggestions?
Jimmy07
Like tach_tech said...get it in a vice and go to work on it. Put some heat on it, too. I had the same thing on a 2010 CTD. Took me an hour and a half working it.
lukebz
lukebz
Sonoma
FYI, I just smashed it with a hammer until it moved in the 1/16 I needed it to. **** it. It stops.
