2013+ 2500 Front Axle Question
Erikk
West TX
I have a 2014 2500 4x4.
Is there any differences in pulling passenger axle shaft on a pre-2013 Ram 2500 to the current truck with the electric disconnect? I need to change the passenger side u-joint and since there is a axle disconnect system in the passenger side of the axle housing I wanted to see if the axle still just slides out before I take everything apart, or if I have to take apart the CAD to get the shaft out or back in. I can’t find anything on this through google searches, everything I found is pre 2013 for the Ram 25-3500 and it’s all talking about solid front axles w/out the CAD.
Thanks for any advice in advance!
Erikk
Erikk
West TX
Well I guess I asked a question nobody knows the answer to, that’s the first time I’ve done that. Im not surprised since I couldn’t get an answer from the service department at 2 dealerships. I did talk to Torque King and got some answers but had hoped to hear from someone on here that has pulled the passenger side outer axle. Can’t find a local shop that knows either.
It sounds like pulling the CAD is required to get the outer axle out and back in.
I also need to know if replacing the seal is required so I can have one on hand and the special tool needed to do that. Typically replacement of the seal is not necessary is it?
huntergreen
Marine Corps Navy Badge
Your question exceeds my skill level. You might want to scroll down to the heavy duty section and post your question there. Good luck.
Erikk
Erikk
West TX
Thanks Huntergreen! I guess reposting it in various forums may be the next move.
mtnrider
Georgia
I've had to pull my 2006 axle a few times but never on my newer truck. Keep us posted if you find a good how-to just in case we have to do it down the road. I would try the other forums, much more HD traffic on those then here.
