2013 Air Dam
TheEnder
4.7L V8
I ordered an air dam for my 1500 after going under my 1500 and realizing that the one i have currently had cracks in the middle. Is it easy to replace, or what?
Sent from my Blue Onyx RAM 1500
Hemi395
Cape Cod MA
Mine is cracked in the middle too. I've tried just about every epoxy and JB Weld available and none last more than a week.
Definitely interested in seeing how hard it is to replace as well.
TheEnder
TheEnder
4.7L V8
Want your BW44-44 to fully lock? Contact @Brandon-w for a locking switch
Can’t wait to do it.
stimpy433
IOWA
If it’s like my 2014, it’s 2 small bolts (one at each end) and the rest are plastic push pins if I remember right. It’s easy to remove and install.
Hemi395
Cape Cod MA
Where did you get it from? I've seen it's over $100 for the Mopar one and around $45 for an aftermarket one...
TheEnder
TheEnder
4.7L V8
Thank you! I don’t think there’s any difference from 2013-2014, so that helps.
TheEnder
TheEnder
4.7L V8
I got a supposed OEM one from eBay for 83$.
TheEnder
TheEnder
4.7L V8
I took off the Air Dam for the time being and i hate the look, looks like my bumper has acne! LMAO
Ic3scrap3r
Mississippi
2017 is the same way. Very easy to remove. I took mine off to make cut-outs for bull bar brackets.
TheEnder
TheEnder
4.7L V8
Just wondering, would the truck being without a air dam until tomorrow (or possibly later if FedEx decides so) hamper performance even the slightest? she feels a little more sluggish without it on.
Hemi395
Cape Cod MA
I would imagine the air is hitting the cross member dead on where the lower control arms bolt to instead of being deflected under it by the air dam. The faster you go the more noticeable it would be....
TheEnder
TheEnder
4.7L V8
That explains it beautifully.
TheEnder
TheEnder
4.7L V8
It came in, but jesus christ, it’s a ***** to get back on. I really don’t know how to. The clips don’t wanna attach themselves.
TheEnder
TheEnder
4.7L V8
Got it on, and it’s beautiful.
Hemi395
Cape Cod MA
Awesome!
So what ended up being the trick with the clips? From what I remember when I looked at it there was 10 or so plus 2 bolts at the end....
TheEnder
TheEnder
4.7L V8
Awesome!
2 pairs of needle nose pliers, clamping down from both sides of the clips, 4 hours of time, and a ton of swearing.....
Hemi395
Cape Cod MA
Thanks!
Sounds about right[emoji23][emoji23][emoji23]
TheEnder
TheEnder
4.7L V8
Thanks!
Also the plastic on the driver side bolt holding in the dam broke off, the metal holding thing & the screw was fine but that part of the old air dam was screwed in more ways than one.
noraa73
