2013 RAM 1500 - Dented Frame
TheEnder
4.7L V8
Hello, As many of you know i was involved with a really bad accident on Sunday. Got truck pulled out, and sent back home, only to look under it and find out the frame has a dent in it right under the engine.
The frame isn’t bent, truck does drive strangely (jumped a curb, needs an alignment) But i’m wondering if this is going to ever be an issue. I’m never going to junk this truck, so i wanna know.
It’s kind of hard to see, but there is a dent. After this photo i cleaned and painted it.
Sent from my iPhone XS Max in my 2013 Magnum 4.7L V8
Brandon-w
Yukon
2015 Ram 1500
That's what about 4 inches wide about ½ indented?
Sent from my SM-A530W using Tapatalk
TheEnder
TheEnder
4.7L V8
I’ll go back under and get a better pic, brb.
Brandon-w
Yukon
2015 Ram 1500
Kk. If you are super worried check the welds on that crossmember and look for newly flaked off paint or cracks. If it's just a decent dent I wouldn't be too worries a wheel alignment will definately help especially if you nailed a curb probly threw your camber and caster out.
TheEnder
TheEnder
4.7L V8
Couldn’t get a much better image due to it being night but around 1/2.
TheEnder
TheEnder
4.7L V8
Yeah, it jumped a 6 inch curb then fell 6 feet onto the passenger side wheel, only onto the wheel. No suspension damage at all. And thank you, i’ll do it tomorrow!
Brandon-w
Yukon
2015 Ram 1500
Holy crap!! Good thing you are ok. Bet ya about **** yourself tho. [emoji51]
It doesn't look too bad looks like Your rack may be touching that member (not sure if it did origionally) but I'd check make sure it didn't ballon out on the back side, I wouldn't panic though looks far more cosmetic than structural damage. An alignment should tell any hidden stuff as well Though and if things are a bit off they can usually fix it within reason.
Edit: I read that thinking you hit a curb and like slid off a side wall that was 6 feet and stopped on ur passenger side not falling off. You literally landed on that tire? Like all the truck weight on that one wheel?????
TheEnder
TheEnder
4.7L V8
Yes, all the weight of the truck went off that wheel.
It’s amazing she’s still running.
Brandon-w
Yukon
2015 Ram 1500
Damn! That's a decent drop. Lucky you didn't roll it! Ok I wouldn't worry about the dent so much as a possible bent frame. I've seem some trucks so some Pretty crazy stuff and come out ok. I'd check that cross Member for sure but I'd also park on a perfectly flat surface and measure the frame up. Make sure it's not bent or twisted. I'll see if I can find any links for doing this. May not be dodge but a frame is a frame same Concept.
TheEnder
TheEnder
4.7L V8
I’ve done the bent frame test and it’s fine, not bent anywhere.
TheEnder
TheEnder
4.7L V8
And yeah, the hill was around 40 feet deeper too. I’m grateful she didn’t roll
Brandon-w
Yukon
2015 Ram 1500
Ok good! Glad that's out of the way. Check the dent out Alittle more tomorrow. Check for fresh paint peeling along the seams and any weird bulges (components touching) and if there's nothing odd paint it make it look perdy and send it! Just not over curbs or drops ur not a Baja racer yet lol!
TheEnder
TheEnder
4.7L V8
Will do. Thank you so very much for the help, lmao.
Brandon-w
Yukon
2015 Ram 1500
Your welcome, I try when I can haha.
TheEnder
TheEnder
4.7L V8
I got great news, the frame isn’t touching the power steering rack.
And from what it looks like the walls of the frame have no buckling.
Brandon-w
Yukon
2015 Ram 1500
That's good news! You may have gotten more than lucky. Get er aligned and call it good. [emoji106] I bet that's a huge relief.
TheEnder
TheEnder
4.7L V8
It is. A MAJOR relief. Once again, thank you.
Lyle Longboat
2011 Ram 1500 5.7 Sport CC
Moosonee, ON, CANADA
I don’t think he planned on being one by the sounds of it lol deadly those curbs. I caught one in a damn Shoppers Drug Mart of all places, through out my alignment and back $160 bucks! Glad you alright and hope all goes well with your Ram!
TheEnder
TheEnder
4.7L V8
Thank you so much. She’s doing great now.
