2013 ram 3500 rear differential chatter when turning sharp
NHRA-1973
NH
Hi guys I have a 2013 ram with a dealer replace diff with only 10,000 miles has chatter when the rear end gets hot turning worst backing up I’ve change the fluid with Amsoil synthetic still does it dealer says it should have two limited slip additive ,Truck currently only has 22,000 miles Wasn’t issue before they change the rear Diff while trying to find a vibration, thoughts? Does the 13 have clutches I know that they did change that not sure on the year.
Timsdually
Jersey
Cummins
I had a '99 2500 with 4:10 LSD that chattered. Changed under warranty once and worked fine for about 15,000. Then on a trip out to CA it started doing it again. Luckily the friend I was visiting knew service writer at Dodge dealer and they took the truck right in. They told me use two of the friction additives. Solved the problem. Never an issue again. Got rid of the truck with 110,000.
Mountaineer83
Charleston, WV
I have a 2016 2500. Changed the gearing to 4.88 and got the same when turning after warming up. Especially while towing. I added a tube of friction modifier and it went away.
Badger 13
North Idaho
2013 Dodge Ram 1500
I was told by an Amsoil dealer that their diff oil has the the limited slip additive, but if you have chatter, add the Mopar limited additive, just an once at a time. I recently changed my rear gear oil with Red Line, and no chatter so far after about driving 2,000 miles. Red Line was just easier for me to get at the time, and from reading, they both work well. I had used Amsoil gear lube in previous trucks with limited slip, and never had any issues.
