2014 Headlights Wiring Diagram HELP!
Savatreatabvr
Phoenix
My truck was in the shop getting front end damage repaired from a wreck I was involved in and everthing seemed fine until I turned on my headlights and only one worked. I played with the wiring harness and could get the other one working temporarily but now both headlights don't work. Then I found a really bad wire spllce but I don't think that's the problem. I can't find a headlight wiring diagram online or even if there's a headlight fuse. Can anyone help with info?
seems fishy
Ontario
I can say that you should return to the autobody shop you had used and ask them to fix it.Tell them you discovered that they spliced the wires poorly.I was a bodyman in a Nationally recognised bodyshop and I saw some guys really do some poor wiring.The reason is that in autobody profits are made by working ..."fast"...Only a small percentage of customers ever bring their vehicle back when issues arise afterward.As you discovered,they can hide that type of shoddy work.You dug around and discovered it.In the shop I worked at the persons who got the cars repaired the fastest received the biggest bonus at Christmas
S
Savatreatabvr
Phoenix
I would rather not deal with the body shop due to the many issues I had with them already and its been 6 months since I got it back so Id rather just fix it myself.
