2014 Instrument Cluster - Discontinued by Chrysler
rpr
GA
2014 Ram Limited
My instrument cluster has been flickering between normal and whitewashed for months. I finally got the truck in to the dealer to have them document it and replace it under the lifetime warranty and they said Chrysler changed the part numbers 2 weeks ago and it’s been discontinued.
That’s my life, no rant, just looking for advice.
Other than digging through a junkyard, what options are there?
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
I'd search here on the forum, multiple instrument cluster upgrades are documented. I would check to see what others have done and years utilized. I have seen a number of threads on people using a cluster from one year of truck to upgrade to another year of truck.
Most are plug and play with some effort.
Most are in the audio and electronics section
Marshall
Sk, Canada
2014 sport
i would check with a different dealer and ask them.
timing to me sounds like, We don't care, go away.
BTW I have a 14, but no lifetime warranty, I did extend the warranty when I bought it new.
bereta1
Ky
Lifetime warranty ? Just went to local yard and replaced my 2016 Ram flickering, code setting cluster with one from another 2016 works, like a charm. Couldnt be happier. Dealer wanted 2300.00 for new one for mine.
R
rpr
GA
2014 Ram Limited
I have a Limited, apparently those clusters are unique to that trim model. I believe the largest supplier for clusters is Instrument Cluster Store and they just advised that they don’t one that will work for my truck.
bereta1
Ky
Had a limited in my hand when I bought mine. Color scheme was the only difference.
mdc1990zr1
Conshohocken, PA
Google instrument cluster repair. I have done a few GM trucks and they have been fine. I believe i used Southern Electronics before.
R
rpr
GA
2014 Ram Limited
I’ll look into that, thanks!
Dusty
Rochester, New York
Wouldn't any cluster up to the 2024 Classic work?
No. Earlier versions used three screw mounting, later used four.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, 18” wheels. Build Date: 3 June 2018. Now at 140540 miles.
Hemi395
Cape Cod MA
Regards,
Dusty
So 2013+ instrument clusters have different variations up to 2024, do you know what year they changed?
Dusty
Rochester, New York
I can tell you that my 2010 used three screws, my 2014 used four. So I believe it was four screws on 4th gens after 2013.
Regards,
Dusty
Regards,
Dusty
They also changed completely in 13,as they went to a single electrical plug instead of the 2 electrical plugs on the back.
You're the only guy i ever seen use the mounting screws as the major differances :waytogo: :Big Laugh:
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
What's the part number they claim you need? What was the original PN?
09-12 significantly different electrically.
2013 trucks had a separate tpms module near the bumper with rf hub behind the rear seat ... and 2014-18/classic had the tpms integrated into the RF hub.
Unless you have a very early 14 build with a 13 setup and based on other posts I've seen over the years
I would expect any 14+ 4th Gen cluster to work as long as you match up the model type (1500/2500), engine type (gas/diesel), and transmission speed (6 vs 8spd).
Reach out to @AllMoparParts.com and maybe they can pull someone out of a hat for you that the dealer can order.
Dusty
Rochester, New York
The reason I use that is because it's the easiest way without removing the cluster to determine compatibility: one screw at the top of the hood visible from outside the cluster, versus two.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, 18” wheels. Build Date: 3 June 2018. Now at 140677 miles.
mvm2
