2014 Ram 1500 6" Lift w/ wobble/vibration
Drew Stanley
Drew Stanley
Mooresville, IN
Not yet. It goes to a lift shop on Tuesday. I installed Bilstein 5100’s back in 2020. Can’t see any obvious issues, but they squeak like crazy! Maybe one is bad? Have a buddy with the same truck and going to swap the driveshaft to rule that out. It’s a single rear axle. Not sure how that could be bent. I did adjust the pinion angle up and down a few degrees, with no change.
Drew Stanley
Drew Stanley
Mooresville, IN
Lift shop just called. Stated the bushings in 3 of the 4 Core 4x4 rear control arms are bad. I installed with the bushing on the axle. I should have installed with the bushing on the frame. I called Core 4X4 and they stated they were having bushing issues right around the time I purchased mine. They're shipping me new ones to pop in. I'll post back after the install to confirm, but looks like I may have found the issue!
Drew Stanley
Drew Stanley
Mooresville, IN
Unfortunately, that was not the issue! Getting so frustrated! There’s only so many things it could be!
Drew Stanley
Drew Stanley
Mooresville, IN
I have some play in the front axles. Is this normal? Wouldn’t this cause steering wheel shake? Antoine have other suggestions/ideas, I can try? Rear shocks look good, but I’m about to replace those I guess.
Hopefully this video works. Axle shake
Pop the axles out and see if your issue goes away.You can drive them with the CV axles removed
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
At least Core 4x4 is sending you the new bushings, I love Core 4x4's customer service ... top notch !!!
Drew Stanley
Drew Stanley
Mooresville, IN
Axles out (PITA by the way) and still no change. Wobble is still there. Time to throw em back in…
Drew Stanley
Drew Stanley
Mooresville, IN
Replaced outer while I was in there. I have zero steering wheel shake. I would expect some if it was front end, right?
Waiting on my buddy to get here so I can swap drive shafts. I’ll replace the rear shocks again after that. About time to trade up!
