TripleJackInGA
What is the correct method of making sure you get all of the air out of the system? I clearly have some in there.
There is a bleed screw on the thermostat housing, but it is positioned in such a way that the throttle body must be removed to gain access to it. Is that the proper method? I had always done this with the engine running.
Thanks!
Thanks!
