2015 Laramie LED's working perfect (so far), but...
GeauxinUp
Navy Badge
Louisiana
2026 Limited
3.0L TT H.O.
Installed LED's into my factory projectors and did all the BCM programming w/ AlfaOBD and so far everything seems to be working perfectly. Lights wouldn't come on at all before the programming...why do 15's have to be such a PITA? Also disabled the fog dropout.
BUT, I still can't get my DRL's to turn on (and yes I've checked with truck in drive). Can somebody point me to a solid list of all the settings to have the DRL's come on to make sure I haven't skipped over anything. I can't even remember what all I have done, because I tried different things from different posts.
Thanks.
Check the "Known Working List" in the first post of the AlfaOBD thread:
That what I followed to set up my Dedicated DRLs on my '15 but you can select whichever location you want, I even have the DRL On/Off option in the radio (8.4) menu. I believe you can check and toggle that same point with AlfaOBD if you don't have the option in the radio.
Just to recap, DRLs illuminate with the vehicle in gear and the parking brake is not set.
GeauxinUp
GeauxinUp
Navy Badge
Louisiana
2026 Limited
3.0L TT H.O.
Thanks crash, I believe this is the procedure I followed, I still didn't have the DRL on/off option in the factory 8.4 (RA4 I believe is what it's referred to as?), and my DRL's aren't working. I had them set to high beam. I've since swapped the factory head unit for an android unit from Amazon (wanted car play), and it does show the on/off in the settings, but I think that's just something preloaded into the software. I'll recheck everything today and see if I can make any progress.
Also, how do I get my signature lines to show below my posts?? I've updated it in my settings.
Looks like you were updating the "About You" instead of the actual Signature box in the settings. I copied and pasted it over for you.
As for your DRLs, when making changes with AlfaOBD it's a good idea to only make one change at a time and wait 5 minutes between when making multiple changes. I was surprised when everything worked first through when I added the DRL to my '15
GeauxinUp
GeauxinUp
Navy Badge
Louisiana
2026 Limited
3.0L TT H.O.
Haha, thanks man. Sorry for the newbie mistake!
Yeah, waiting seems to be hit or miss. When I disable the fog light drop out, it was instant, but other things were an on-off-on and wait. Will follow up when I get a chance to work on it.
GeauxinUp
GeauxinUp
Navy Badge
Louisiana
2026 Limited
3.0L TT H.O.
Ran back through all the settings, and I now have the fog lights functioning as the DRL’s!
I also checked for any faults before logging off alfaobd, and I’ve got 2 codes now with no CEL. Should I be concerned about these causing LED issues down the road? My test drive (about 30 miles) last night didn’t yield any problems with flickering, drop out, etc.
B162A and E
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
CBC Features: DRL Configuration: Select “Optional DRL”
CBC Features: DRL Lamp location (several to choose from, high beam, low beam, fog lamp, dedicated) Known working high beam, low beam, turn signal and fog lamp.
CBC Features: DRL Dropout Enabled: Select “yes”
ECU 3: DRL Customer Setting Enable/Disable: Select “yes”
Customer Service Menus: Daytime Running Lights CSM: Select “yes”
