Jeepwalker
- Sep 8, 2017
- 4,243
- 5,366
- Location
- WI
- 2012 Reg Cab, 4x4
- 5.7 Hemi
If you can tent-off the valley, get an oversized jam nut (they're half as thick as a regular nut) at the hardware store. Or use a regular nut. Then weld from the broken bolt center to the nut. Then remove the nut (and hence the bolt) with a socket. Boom, it's that easy! Again, you'll want to tent the area off real well.
Or you could drill out and hold a shop vac hose near the bolt to suck up the shavings (also tent off the valley). Use extractor as you were thinking.
Either way will work probably just as quick.
