2016 ram 1500 rcsb build thread
B
bonnyjliss
oregon
well one coil was too much lol
i think im going to put the stock spindles and belltech springs back on for now
B
bonnyjliss
oregon
i put the belltechs and stock spindles back on. i should start doing this hourly now i could make a ton of money
i'll take a pic later
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
You could take out the lower spring rubber spacer and achieve some minor lowering without cutting the new springs.
Anything you do to your front end is going to require an alignment
B
bonnyjliss
oregon
i put the stock spindles and belltech springs on, had to put on new sway bar end links cause one of the nuts stripped out
i had it aligned after and it drives really nice and straight now. looks good. rides pretty good.
Ran [email protected] tonight
No traction off the line
What was the DA/Density Altitude being naturally aspirated the trucks are very sensitive to the DA.That's about on par with what most stock R/T's run in Edmonton when the DA is around 4,000 ft.
If you're spinning hard off the line leave the traction control on,it reacts faster to wheel spin then your foot does
B
bonnyjliss
oregon
yeah i tried both ways and also lowering the rears to 15psi and setting my qa1s to lowest setting. no traction at all.
it seemed to get the best traction with 40psi in rear tires and qa1s set at 8 LOL
whatever, i might go again tonight, my son and i has a lot of fun. hes 16 and first time going to drags to race.
he ran his 03 g35 sport he ran high 14s but trapped 98mph.
i ran his car once and ran mid 14s at 99 lol not bad... his car has headers full exhaust intake and tune
B
bonnyjliss
oregon
yeah he didnt do the best job recording one of my runs lol.
truck also hit the speed limiter like at 100 right after i crossed the line several times. i swear i had it over 100mph before without hitting this limiter but maybe i didnt.
B
bonnyjliss
oregon
its sea level, PIR has seemed like a slow track
There's still a DA number at Sea Level,especially in the summer.Mission is at Sea Level,and at this time of year it's not uncommon for their DA to be well above 2,000ft,and Missions just north of you.
B
bonnyjliss
oregon
anyone know what those things people put on their trucks sometimes right on the front lip of the top of the cab, sometimes they have lights in them or sometimes not. i can't tell what those things are called.
i have a little bit of clear coat that is damaged on the roof and i want to just cover it up with something simple until i can fix it right.
B
bonnyjliss
oregon
i guess they call them cab lights, but i want a solid piece across the front, that looks like a little spoiler or something
Rav3ncroft
Indiana
2018 RCSB Sport
I'd be interested in seeing how a rcsb looks with a visor. I've thought about it but never pulled the trigger.
B
bonnyjliss
oregon
yeah im not sure if i would put one that looks like those on it, something smaller akin to a spoiler or something
B
bonnyjliss
oregon
i got a trinity ex and put their tune and trans tune on needless to say im not impressed at least with the transmission tune it seems the same except shifting down earlier? which is basically just annoying
i was hoping it would just increase the line pressure / decrease the target shift time or whatever they do in in these transmissions.
B
bonnyjliss
oregon
i put the hemifever tune on using the trinity ex and its much better than the diablo sport 91 tune, the transmission tune is better
Pull Ya
Cedar Creek, Tx
Almost a half second improvement---not to shabby--. Have you replaced the stock drive shaft yet?
Jay
