2017 1500 Exp 4x4 3.21 to 3.92
appzattak
Jerome, Idaho
Searched a ton, and cannot find a definitive answer. If I were to do this upgrade, does the front also need to be done?
Sent from my iPad using Tapatalk Pro
appzattak
appzattak
Jerome, Idaho
Yes Sir it needs to be done, well if you ever want to use 4wd again.. :)
Thank you!
Well that does not make it so desirable now, just expensive...guess I'll pass.
RoadRamblerNJ
Mountain City, TN
392 Hemi
Oh, Haill yeah it needs to be done! You'd get about 2 feet before you found the weakest link in your drivetrain. Gear oil is hard to get off the driveway lol. Seriously tho, 3.21:1 and 3.92:1 gear ratios refers to how many times the driveshaft revolves for one revolution of your tire. More revs = higher engine rpms at every speed. Both rears MUST be the same or.....BLAM! PS: I loved the 3.92s in my 1500 so much, I bought a 2500 4x4 with 4.10:1. More is always better!
Pull Ya
Cedar Creek, Tx
If you want to talk to someone that has done this switch in gears contact member "wild one". He can give you all the details and the app. cost of doing the gear swap.
Jay
