2017 1500 Factory trailer brake stopped working.
jeff120
tucson, AZ
Hi All,
I have about 11k miles on my 1500. I've been pulling my 23' trailer (2010 year) since the spring (about 5k miles).
Today while driving, I heard the beep and it said the trailer brake was disconnected. I pulled over, unplugged/plugged back in a few times, checked for a loose harness, and it still wouldn't work.
All the lights (turn/brake, night) work fine. It just seems to be the brake. Any idea where to start looking? Has anyone had this issue before?
Ricks Ram
Hi All,
I have not heard of anybody having this issue with the factory trailer brake. They seem to be pretty reliable. I think the first thing I would be is check all the wiring in your trailer connector and then check the wiring on the back side of the truck plug see if anything possibly came loose or got damaged. If you know someone that has a trailer with electronic brakes you could always plug into their trailer and see if it connects to your truck. It might help you narrow down if it's the truck or your trailer with the issue. If it ends up being your truck your still under warranty. I would just take it in and have them figure out what's going on.
Sent from my SCH-I545 using Tapatalk
Sounds like you do a lot of towing, it could be a worn out or bad magnet in the trailer brakes?
https://www.etrailer.com/question-10824.html
F11 is the fuse for the trailer brakes on the truck (The rest of the fuses for the trailer plug are F28, F29, F30, F53 & F81).
J
jeff120
tucson, AZ
Thanks for the info. I hooked up to my neighbor's trailer and it registered the brake. Taking the RV in for some brake work!
