2017 8.4 into 2018 2500
Robdame03
Statesboro Georgia
6.7HO
I have a totaled 2017 ram 3500 with the 8.4 I would like to put into a tradesman 2018 3500. I have access to everything in the 2017 blower motor etc. what all do I need to swap out? Will the radio even work in the 2018?
Thanks
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Thanks
@Mpgrimm2 might be able to help. You might need to purchase one of his custom harnesses to get full functionality from the USB hub.
R
Robdame03
Statesboro Georgia
6.7HO
Aside from the usb hub.. what is needed from the donor truck? I know the obvious things such as the bezel. I have already installed the heated cooled seats and got them working from the Push button panel.
Any help/ insight will be greatly appreciated
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
It will depend on a few things like if the new truck has 4 speed or 7 spd fan and if it has 5" radio with Handsfree calling, satellite radio and BuCam on the radio among others. At a minimum need the ...
17 RAx radio
8.4 bezel (Single Zone or Dual Zone ATC?)
HVAC module behind pass Air vent
Fan motor resistor
Maybe more?
> Mirror/mirror harness?
> Headliner Mics?
R
Robdame03
Statesboro Georgia
6.7HO
17 RAx radio
Fan motor resistor
Maybe more?
> Headliner Mics?
Do you have a harness to make the Atc controls work in the truck it currently has manual controls and 4 speed fan. Thanks
Mpgrimm2
SC
5.7L
Yes... See messages.
