2017 Ram 1500 Front and Rear Bilstein 5100 Install with Rear 1" Spacer. WHATS NEEDED?
DavidRussell
Boise, Idaho
5.7l HEMI
Ive got front and rear bilstein 5100s.
PN: BIL24-187367 and PN: BIL24-187374
Also have Daystar 1" Rear coil spacer.
PN: KC09116BK
Up front. I can use the Bilstein with it being set to 2.1" lift with the stock coil. Nothing else needed? I am not setting 2.8" to avoid replacing the upper control arm.
In back.. This will make it so I can lift the rear 1" without changing coils right? Or am I mistaken here?
Also, do I need to do anything with bump stop?Need to do anything with break lines or Sway bar? Am I missing anything at all?
Sorry for all the questions I just don't want any surprises.
Mopar1987
Livingston TX
That’s about exactly what I’ve got. I went 2.8 but also put different upper control arms on. Nothing else needed for you front or rear
kurek
Northwest
You're going to need either a 21mm crow's foot wrench or the Thuren rear shock nut set.
osprey ram
09 1500 4x4
4.7 lit.
I have 09 set-up w/what you're referring too. only thing I added was air lift 1000 in rear. Wore out rear springs, helps with hauling.
Don't know if you noticed,but this thread is over 4 years old
