2017 Ram 3.6 Misfire issues
Boony
Trinity, Tx
My Ram started to run very rough the other day but never showed a check engine light. I hooked my scanner up and it showed 6 codes. 3 for P0306, 2 for P0300 and 1 for P0303.
I changed the coil and plugs for the 3 and 6 cylinder. It still shows the same codes as permanent but still has not turned on the check engine light.
The little Eco icon comes on and off and dings every now and then. Any help or info is appreciated.
CHUCK31979
Columbia MD
2022 1500 Crew Cab
Had a misfire code for #3 cyl. about 130000 miles. So I did all 6 coils(NGK), spark plugs(NGK) Bosch reman. matched fuel injectors from CS performance, aluminium oil cooler, air charge temp sens, MAP, Crank and Cam posistion sensor and knock sensor. Truck is running much better, milage up about 1-3 MPG
