Thomas Obieglo
Are the caster adjustment bolts/cams supposed to be close to the same position?
I've read the Thuren specs and they indicate the cams should be no further than 1 notch apart. However, I don't have Thuren coils or Fox shocks, rather ... a 2" leveling kit with coil spacers, radius arm drop brackets, adjustable track bar, sway bar drop brackets and shock extension brackets.
I just brought the vehicle home from an alignment and I noticed 2 things: 1) the front driver's side is 1/2" lower than the passenger side and 2) the caster cams are 180 degrees different. Driver side is pointing to 12:00 and the passenger side to 6:00 o'clock.
That just doesn't seem right. Would appreciate some feedback.
2018 Power Wagon
2018 Power Wagon
