The 4 digit pin is only for the rf hub. It won't do you any good having it if you don't have a way to communicate with the truck. The bypass harness doesn’t get you the pin. FCA added a security module in 2018 blocking access to any of the truck's computer's and modules as a anti hacking feature. The bypass harness does exactly what it says and bypasses the module. Even dealer's can't access certain things with approval. This harness allows access through the obd2 port to access the truck's computer's allowing changes. The only thing you could do is brick your truck to the point where a reset by a dealer couldn't be done. And depending on the dealer may not "warranty" a reset if you do mess something up that backtracking with alphaobd couldn't fix. Depending on the dealers they may give you the pin for free of charge, or they may charge or say they are not allowed, which is a lie. If they want more than $15 there is a app called Chrysler pin puller that can get it for $15.
2018 2500 6.4L Tradesman
