2018 Ram Switchbacks
DC Tradesman
Washington
I'm having an issue with settings for front turn/running lights. Have ALPHA OBD & OBD-MX.
The switchbacks are intermittently flashing white than turning amber. Kicking fault codes.
The switchbacks have built in resistors to prevent fault codes & hyper flashing. I have stock reflector head lights. The built in LED resistors should keep me from using LED light settings.
If anyone has insight to the correct setting information please let me know.
Thanks
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Thanks
Turn on the LED settings in AlfaOBD.
DC Tradesman
DC Tradesman
Washington
Thanks for replying. I did try the led settings for front turn & running lights no joy. I contacted the bulb manufacturer they’re sending me a newer version. They believe it will correct the problem. I’ll know in a few days.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Your switchback harness would be the culprit next. Once you've removed the pwm function for LED's the truck should function like normal.
Since it acts up when the switchback is changing color or activation or whatever I would investigate the harness.
Got pics of what you're working with?
DC Tradesman
DC Tradesman
Washington
To much snow today & tomorrow to even think about fooling with it. I have a set of switchbacks W/0 built in resistors. I used a set of resistors from Amazon. Lights worked perfectly but with two fault codes. Once stock bulbs replaced faults cleared.
