2019 RAM 2500 Laramie Longhorn - driver's side headlight assembly has moisture in it and is not working.
Romans623
Southern Ontario
Cummins Diesel
The headlight assembly has moisture in it and the daytime light, headlight, high beam, and turn signal are not functioning. Has anyone experienced this problem and have a fix for it?
TRK_GANG74
Navy Badge
Va, Hampton Roads Area
You need a new headlight assembly. They are sealed units with no serviceable parts to replace. Use this site to find new new one. Allmoparparts.com and look up by VIN or car parts.com
blue ghost
Pennsylvania
2013 Ram 1500 sport
Since all are out, I would first check to see if the plug has come loose. To access them, go in through the door in the wheel well. And slide the release(as well as any screw under hood). There are numerous video's on the internet, on how to do it. It is simple but can be a pain.
etbrown4
If you need a replacement, forget mopar. Amazon has excellent deals on Akkon, and they're good headlights.
CWhatMexy
Virginia
2020 1500 Laramie 4x4
HEMI 5.7L
If you haven't bought a headlight yet. I just bought a replacement for my taillight for a crack and moisture. Got it off AmericanTrucks.com pain around $200 for OEM. Works great.
bradstephens25
