2019 suspension lift questions
Alloway
Ohio
The 35 in that picture only looks a hair bigger than the factory duratrac and the 37 dwarfs the 35
Alloway
Ohio
What Brand is the 37 and 35 in that picture?
crazy jerry
WY
35 is mastercraft (cooper). definatly on the narrow range of the scale for sure. got another brand 35x12.5 and its easily 3/4" wider. 37 is maxxis
Ubem
Waukegan Il
CFB2D3E0-823B-4AC9-B19B-E4CC62292D00.jpeg 644B211B-F095-44BD-B1E7-3D0F11A49D40.jpeg B8EE4207-C69E-43EC-932A-3CC5C0F55FF8.jpeg B29B5BA1-283F-41BA-99DA-D9A17676EA97.jpeg
I am running 37x12:50x20 Nitto Trail Grappler tires on my 2019 Ram Big Horn Gen 5 on Fuel Hardline 20x9 rims with a +1 offset and a 6 inch Pro Comp lift kit. The lower splash guards on the rear edge of the front fenders had to be trimmed and the only problem I encountered with tire rubbing was contact with the rear lower edge of the front fender liners when turning and hitting a bump in the road. This was eliminated by installing a small section of Delwin rod in the recess section of the lower rear portion of the front fender liner. The rod was then attached to a medium sized spring inserted through the back side of the liner and then attached to an inner body bracket as shown in the attached pictures. This installation pulled the liner back approximately 2 inches and eliminated any further tire rubbing contact.
pwjouster
South Florida
i almost made the assumption that was factory with the fit and finish there.
very interesting idea there.
