2021 3500 Dually rear spacers
bnscott
Santa Barbara (Looking for remote)
Cummins Diesel
I am looking to change my tires out to NITTO Ridge Grappler 285/70r17. I am looking for 2" spacers for the rear tires. Has anyone done this and if so, can you link to the spacers or if I can go with a 1.5" spacer, that will work as well.
Thanks!!
stevenP
northern Indiana
2022 2500 Longhorn
6.7L Cummins
I went with Nitto dura grapplers on my dually, as a replacement for the junk nexens. I didnt need a spacer.
2500 hd
NC
I'm curious as well.
2500 hd
NC
Pictures if possible..
nlambert182
Huntsville, AL
I've never had to run a spacer on my dually. What size did your truck have on it stock? Go back with the stock size or at least something a bit narrower. I wouldn't recommend running spacers for the reason Tron mentioned above.
2003F350
6.7 CTD
If you aren't going to be towing and it's going to be a pavement princess, or if you have money to blow, sure, go ahead and run those spacers with those monster tires. I know everyone wants their dually to look like the Yellowstone truck, but that truck wasn't going to see a long life in the real world, and its payload was reduced JUST because of the spacers they had to run to achieve the look.
I THINK stock most duallys run 245's? Been a while since I looked. I want to say you can get away with 265's with no spacers and still haul full weight, and I think 285's will fit but will rub if you start to get close to max weight. DO NOT TAKE THESE NUMBERS FOR GOSPEL, IT HAS BEEN A WHILE SINCE I'VE LOOKED AT DUALLIES SO PLEASE LOOK INTO IT. Tire Rack will tell you what the stock sizes for your truck were with just a few clicks.
2500 hd
NC
My stock truck came with 235's
OC455
Central NY
235 80 R 17's are the factory size. I've seen 255 80 R 17's run without any spacers and they have the 123/120 load index rating. They would actually be taller than the 285 70 R 17's that you are looking at and only 3/4 of an inch wider than factory size. Should be no clearance issues or the need to use any spacers.
I was just reading this posting
I wonder if a wheel manufacturer makes OFF SET Rims for Dually 3/4 or 1 ton Rams
That way, you would not need a spacer
i found my answer
