I worked in the fueling industry for MANY years. There is a federal requirement for flow rates not to exceed 10GPM delivery for regular gasoline/blends. This is to allow vapor processing within the vehicle's EVAP system. That's not to say that all abide by that, as there are work-arounds to increase fuel delivery speed. That's also not to say that anybody EVER checks flow rates based on "this pump is way too fast". Most inquiries are for slow delivery speeds. Automatic nozzles shut off based on a venturi system. It's an air exchange taking place. Next time you are about to fuel, look at the down side of the nozzle spout. You'll see a calibrated orifice that is exchanging air while fuel is being delivered. Once that orifice is overcome with fuel presence (think of spout inside filler neck, tank fills, neck fills, now orifice submerged in fuel), CLICK. Same happens if enough vapor/pressure is present. It overcomes the venturi and trips the valve inside the nozzle to stop fuel flow.
On vehicles with diminished EVAP or blocked EVAP systems, this is what is happening most of the time. The air is not escaping the tank and causing premature shut-off. Or fuel is backing up into the fuel neck causing same result.
