2025 Tungsten HO Hurricane - Third Battery Replacement by 7,851 Miles
TungstenOwner
NJ
Hurricane twin-turbo engine
I am curious if any other Tungsten or Hurricane HO owners are experiencing repeated battery failures.
My truck is a 2025 Ram 1500 Tungsten with the High Output Hurricane twin-turbo I6. The truck currently has 7,851 miles.
Battery replacement history:
• May 14, 2025 – 839 miles
• December 11, 2025 – 4,557 miles
• June 19, 2026 – 7,851 miles
The most recent incident occurred after I drove the truck to work normally in the morning. When I went to leave work that evening, the truck was completely dead. I could not unlock the doors electronically, the dome lights would not come on, and the dashboard was completely dark. The truck required a jump start just to get it onto the tow truck.
The dealer replaced the battery under warranty and performed a draw test but reported that they did not find any abnormal current draw.
The truck has received several software updates over the past year, including one within the last couple of weeks before this most recent failure.
At this point, I have had three battery replacements in approximately 13 months and less than 8,000 miles.
Has anyone else with a 2025 Tungsten or Hurricane-powered Ram experienced similar issues? If so, did your dealer identify a root cause, such as a module staying awake, a battery management issue, software problem, or something else?
I would appreciate hearing what others have found.
TungstenOwner
TungstenOwner
NJ
Dealer confirmed both main and auxiliary batteries failed GR8 testing and were replaced. This has now occurred three times at 839, 4,557, and 7,851 miles.
I was reading an article the other day on the 2025/26 Ram truck with the Hurricane engines having dashboards go blank due in part to high amperage draws across the grounds in the electrical system. Have to wonder if the battery problems are stemming from the system not properly charging the batteries.
GeauxinUp
Navy Badge
Louisiana
2026 Limited
3.0L TT H.O.
Yeah, I’m betting those batteries ain’t just going bad on their own. Something is killing them, and until they figure out what that something is, they’re gonna keep replacing batteries
RamTech82
Denver
6.4L Hemi
I’m working on one now it spikes from 12-20mA to 130mA there is a module waking up I’ll let you know what I find out her Dealers have just replaced the batteries 2 times and it keeps draining the batteries over a few days of this happening
