2500 stuck in 4th gear
Cgrant726
Baltimore
2016 2500 6.4L Big Horn CC. Warning light came on, truck downshifted into 4th gear, and won't come out. Luckily was right near my house. Waiting on dealer to come tow and drop off loaner. Anyone else have this issue?
Moab_Rockstar
Lake Orion, MI
5.9L
Which warning light(s) did you see?
Sounds like a sensor on the engine went **** and put you in limp home mode. There are a number of faults that will cause a fixed gear reaction like that. If you have a OBD reader, the DTC codes will tell more.
Cgrant726
Cgrant726
Baltimore
The check engine/transmission. I don't have a reader. Dealership just loaded up to take in. It's really irritating. 6 months old. 11k miles.
Fairbanks, AK
That happened to me too, it would launch in 4th and stay there, even after power cycling the engine. The tech ended up putting a new solenoid kit in it and it fixed. Apparently they have seen it before where the solenoids go bad in the valve body. Not a huge deal, until it goes bad. Mine had just a couple thousand miles at the time. With all the thousands and thousands of those things that they make, there are bound to be a few bad eggs, your warranty will cover it.
Cgrant726
Cgrant726
Baltimore
You were correct. Solenoid was bad, they replaced. Thanks
pjcodner
Burnsville MN
Well crap. It happened to me a while ago. I was right near the dealership. I took it in and they reset the code so I could go home. Brought it in a few days later so they could look it over and of course they didn't find anything. They applied 4 updates to the transmission and it has been fine ever sense. They tole me it was a low voltage issue to something in the transmission that caused it to go into limp mode.
I will be sure to let them know if it happens again to check the solenoid.
