3.6 subtle tick at idle
22Tradesman
Los Angeles
3.6 Pentastar
Hey everyone!
I just started to notice my 3.6 has developed a slight tick at idle. I first noticed it while on my little road trip out to Palm Springs this past weekend. It seems to go away when driving the truck. Oil pressure is 31-32 psi at idle, and the truck's oil level is good. Currently at 9887 miles and the truck has been super solid otherwise! Should I be nervous or is this a normal sound these Pentastars make? What do you all think? Thanks!
Video here:
https://www.youtube.com/shorts/j-khLnAGmZQ
Atcer2018
Virginia
Hey everyone!
Video here:
The Pentastar has been known to eat a cam or two over its production run but that was supposedly corrected in 2018 with improved internals. At less than 10k miles on a 2022 you should still have warranty left so I’d personally get it into the dealer soon. Don’t be surprised if they tell you it’s normal. After watching your vid I could hear a slight tick but to me it sounded more like injectors than lifters. Does the sound accelerate with increased RPMs? If you don’t drive it for a few days is tick more pronounced? It could also be a bad serpentine belt tensioner but if you’re still under warranty let the dealer figure it out.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Hey everyone!
Video here:
It's been a while since mine was that new but I feel like I noticed the same change a long time ago and it's been that way ever since. If I were to record my gen2 3.6L it would sound like this too. I think yours is a 3rd gen 3.6L but I'm not sure if that is the case with Rams.
22Tradesman
22Tradesman
Los Angeles
3.6 Pentastar
Thanks for the reply. I was leaning towards injectors as well. I don’t think it increases with rpm, I can’t hear it when I rev the truck up. I still have about 4 years left on the factory warranty so I'm in luck. My plan is to not worry about it for now, but when I need an oil change I’ll take it to the Dodge dealer and mention it to them.
22Tradesman
22Tradesman
Los Angeles
3.6 Pentastar
I appreciate the reply. Im guessing that my truck has the 2nd gen engine. Are all of the 3.6 etorque engines in the 5th gen trucks 3rd generation engines?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
E Torque could almost be considered a 4thgen 3.6L. The PUG 3.6L made changes to icrease efficiency and performance. On many vehicles with the PUG, it's easy to identify as it adds a EGR cooler to the engine but I'm not sure if that cooler is present on Rams...if so it is definitely a 3rd gen.
Atcer2018
Virginia
What’s a PUG?
22Tradesman
22Tradesman
Los Angeles
3.6 Pentastar
A little update, I wonder if it’s an exhaust leak instead of an internal tick? I washed the truck today, and started it up to let it idle while I wiped under the hood. Everything sounds completely normal with the hood open. When I shut it, I could hear the ticking. I climbed underneath the passenger side wheel well, and it sounds like the noise is coming directly from where the catalytic converter mounts to the cylinder head. I didn’t touch anything because I didn’t want to incinerate my hand. Is that a possible issue with these engines? Is there an easy way to check if this is the case? I know it happens on the Hemis. Thanks again for all the replies.
Atcer2018
Virginia
I have no knowledge of the 3.6L breaking exhaust manifold bolts. You mentioned the catalytic converter, they have a heat shield and the spot welds may have separated causing a rhythmic tick. Never heard of it but it’s possible.
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Check the Flange on the Y pipe !
The studs rotted off in mine and was replaced under warranty!
A few years later the studs rotted off again and my mechanic drilled out the studs and put a Nut and bolt in place
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Please UPDATE what you do find out ! Thanks
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Y pipe?
22Tradesman
22Tradesman
Los Angeles
3.6 Pentastar
Mine does too. 5W30 is the way to go.
I agree. I’ve seen other people put 5w30 in to quiet them down. I think the 3.6’s are just in general a little noisier than other engines. The 3.6 in our Grand Cherokee L makes way more noise than my ram, and it’s been problem free for the past 3 years.
22Tradesman
22Tradesman
Los Angeles
3.6 Pentastar
Will do, but in the mean time i’m just rolling with it. Like I said to Atcer2018, I think these 3.6’s are a little noisier in general from what I’ve read, and heard with our 21 Grand Cherokee L. I haven’t noticed any changes since I first heard the tick, and the oil pressure and level looks good. I’m gonna try 5w30 on my next oil change.
ramffml
ramforum
This is interesting. I had a 3.6 in a 2012 jeep before getting my ram and I was pretty shocked once I started listening closely to my truck on stock oil and brand new. The 3.6 was dead quiet in comparison, though I did get that cold startup rattle every once in a while on the 3.6 too.
All that hemi noise is literally why I started researching oil, locating bitog, seeing burla post there about redline and then coming here to this forum to discuss.
Guess not every engine behaves the same. :shrug:
