3.7 slant six swap to 440 info?
Justinkdillon
Yakima Washington
3.7 slant six
Hey guys new to the group and couldn’t find a post with info I’m looking for
Just picked up an ‘81 d150 with the slant six and manual trans with the intentions of making it a project, I have a buddy that has a 440 he’ll give to me and was wondering what mounts, bellhousing, and flywheel will I need to make this work along with other things I’ll need thanks in advance
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
welcome! post a pic of your ride!
anyway, are you sure the slant 6 manual will be able to handle the 440 power? I think 81 was still the A833 but not sure. either way, as far as I can remember, not all A833 were the same. the ones behind V8s were made a bit beefier. for 100% correct info, I'd check in with Passon Performance. Jamie Passon is the king of A833s.
since it is a full swap maybe consider the NV4500 5 speed? I was going to go that way until I disassembled the clutch/brake pedal assembly. my clutch pedal linkage 'hole' was ovalized and no good. ended up going 46rh auto instead.
Motor mounts you might have to hunt around. not much is made for the red-headed step children dodge trucks from 72-93. I've seen mounts for the 400 (6.6L) but no 440s. if they are the same/similar blocks (like the 318 and 360) then that might work. otherwise, like any good mopar project, get out your plasma cutter and welder, you might need to make some custom mounts.
good luck and have fun!
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
It's doable, but you will need to google around to find all that is needed. I have not found a one stop list for everything needed though.
jakefrancis127
the four speed you have will work just fine. you can search ebay to find a original big block bellhousing, the bolt pattern will be the same. not sure about where to find the motor mounts. flywheel and clutch kits can be had from summit, etc. probably going to have to go aftermarket with the radiator, the stock one wont cool enough. best of luck, post progress pics
u2slow
BC, Canada
Cummins 6BTA
I've borne witness to others chasing bits and pieces for bigger engine swaps. What a costly PITA.
That's why after I picked up my 400B core to build... I picked up a whole rusty W300 truck (400 & 4speed).
Nicholas Lozano
