Sounds like we're both of the same mindset then with a quarter of a tank. Been there before with missing an exit myself, or place I planned on not open/out of fuel I came for has happened before to me as well. Diesel is expensive enough as it is, we certainly don't need to be sneezed on amount. Hope they get that pump checked out!I don’t typically run that low — the 31.6 fillup was a rare instance and with the one from the photo above I missed the turn for the gas station I intended and a quick google check indicated I could make it.
I usually like to run no lower than a quarter tank. Definitely would prefer to not prematurely be replacing my fuel pump and other parts!
$4.29!
I have a 32 gallon tank — 3500, 8ft bed, crew cab diesel.
It looks like it might be just visible on the right edge of frame, above the black nozzle "housing".Different state that mine, but what I've noticed in my area is the inspection stickers on the pump showing that they've been tested. I don't see any on this pic, though may be out of view?
You're braver than I with how low you go on tank. Hope you're adding something to help keep things clean in your tank - and have always been doing that. I had some diesel fuel issues in previous F250 that ended up replacing all the injectors and wow were they expensive! Good luck there!
It was. Turns out I’m an a$$hole lol.It looks like it might be just visible on the right edge of frame, above the black nozzle "housing".
Another reason not to let the fuel run that low is prematurely burning up the fuel pump. The fuel pump needs the fuel surrounding it to help keep it cooler and lubricated. That's what my mechanic recommended to me.
