zeustheram
- Aug 30, 2014
- 49
- 2
- Location
- North Caroolina
- 1997
- 5.9 360 V8
alright well my 97 ram 2500 has the 5.9l 360 v8. I was on my way back from Virginia and gas light popped on being on the highway i had to drive few more miles to get gas. i got gas and then 5 minutes later going down the high way the truck started to surge and almost shut off then oil light came on. i put oil in made sure it was right on the dip stick and drove it back home. anytime i got up to around 65 the truck would start to surge and run bad again. so i put seafoam in the gas to treat the gas cause it was all the symptoms of bad gas and i changed the oil just in case. well i cranked it today and now the motor sounds like a tractor and has a small tick noise with the tractor noise. i was looking over the motor theirs no leaks but the center of the exhaust manifold on the passenger side started leak a small amount of high smoke. and sounds like its running at a high idle.
Im completely lost with whats going on. no check engine light is on no oil lights are on and everythings running normal on the gauge cluster.
