392 Swap - High Oil Temps - What Would You Do?
Jwrigh12
Somewhere Notrh of the Equator
My oil temps run right around 190/195 at 90 mph on a hot day with this set-up on my 2014 4X4,but it's also a 5.7,so if it'd work to bring your oil temps down to where you want on a 6.4 i'm not sure.One benefit was my oil pressures did come up with the dual filter set-up compared to the first single filter set up i ran.That's with 3.55 gears,8 speed and a 31" tall tire to
Ummmm... sorry for quoting so far back in the thread... but what in the name of sweet slippery goodness is this?!...and where can I get one?
In Phx and I'm not loving the Temps I'm seeing at the moment.
tstein88
Madison, Wisconsin
So I've got a 2013 crew cab with 3.92 rear gears, 8HP70 swap, and 392 swap with MMX NSR cam, stock bottom end, ported manifold, etc. This oil (Redline 5w-40) runs HOT and we're not even into summer (I am in TX).
Little background - fall of 2020 my 165K stock 5.7 decided to tire out and with the cost of new trucks and what I had recently put into the truck, I decided to keep it and upgrade the engine. Then I spent the following 2 years dealing with weak transmission issues and ended up swapping to an 8HP70. I finally got everything buttoned up and have been daily driving the truck since last summer/fall. At that time, when cruising 90 down the highway, I noticed the oil would routinely get well over 240-250F and raise the coolant temp up to around 220F - I have a 185F coolant thermostat that actually works but the delta between the engine's fluids could only be so high. Even putting around, the oil would always get over 220F and would probably average around 230F with reasonable highway speeds (60-70MPH), the coolant could somewhat manage this delta and would lower a bit, maybe around 200F.
So late last fall I put on an oil cooler (34 row 59K BTU) with 185F thermostat in the filter sandwich adapter. One of the problems with this setup was I had to use the small oil filter due to the 1.75" thick sandwich adapter. I thought the oil pressure was down ~5 PSI but I think it may be closer to a 10 PSI drop with the large cooler, I foolishly wasn't recording oil pressure and temperature on my logs until recently. Well that cooler got me through winter (great temps, pressure not so much) but I never liked the small filter and stumbled across a low profile sandwich adapter that allowed me to use the large filter (RP 20-820) and I put this on around mid-January. I did not realize that this low profile adapter did not have a thermostat of any kind and was full flow to the cooler all the time. So I took that off after two weeks and removed the cooler entirely and have been running nothing for about a month now but this oil is HOT and our ambient temps are only around 80F in the evening when I drive home. The coolant gets up 200F with the oil well over 240F cruising at 90 MPH for around 15-20 miles. The coolant falls back down to 185-190F when cruising at reasonable highways speeds and the EOT falls to around 220-230F.
So without the cooler, for oil pressure I would have low 60s at cold start idle, high 60s into the 70s at cold cruising, high 50s/low 60s warm/hot cruising, and plummet to high 30s at idle (800 rpm for cam). So I adjusted my tune (HPT) to raise idle depending on oil temp and basically it is unaffected until around 176F I bump it up to 825 (800 base), 875 rpm at 212F, and 975 rpm @ 240F all scaling between and it keeps me in the high 40s oil pressure at warm-hot idle. I would prefer higher idle oil pressures but c'mon 975 rpm idle on a street engine with tiny NSR cam seems about the limit of reasonable.
So with that said, what are other 392 truck owner's experiencing? I know this engine has the oil squirters to keep the pistons cool and I am sure they are working which is heating the oil considerably more than the 5.7 but also lowering idle oil pressure. Any other engine I would be okay with that pressure but these engines, particularly the lifters and camshaft, don't like to idle with low oil pressure. What would you do in my shoes?
1. Run 5w-50 oil - I already have to keep this handy for the Roush-charged mustang so it would allow me to consolidate engine oils.
2. Remote dual filters (30-8A)
3. Run the large oil cooler I have with a remote dual filter setup, would be rather expensive in parts setup
4. Run a smaller oil cooler
5. Run a smaller oil cooler with remote filter(s)
6. Hellcat oil pump - last ditch effort, I don't really want to tear into this
7. Moroso High Cap oil pan - also don't really want to headache with this
8. Some fancy A2W setup - big $$$
9. Nothing, f'in send it!
10. Some combination of choices or other??
tstein88
Madison, Wisconsin
I finally ordered and installed the new honeycomb grille inserts this past week. The results at first seemed not all that great, other than aesthetics as the stock sport grille has not aged well. But after truly looking at the numbers and pushing it this morning, the results are a bit better than they initially appeared. When cruising on the highway in the AM with cooler temperatures, the ECT always ran at 185F while the EOT got up to maybe 206-210F after the strenuous 90MPH cruise. In the afternoons, ECT would be anywhere from 192-200+F and EOT usually 208-212F range, maybe a bit warmer if I had some road rage. Now with the honeycomb grille, the mornings only change was a few degrees drop of EOT, maybe in the 203F range, ECT was and is constant at 185F. In the afternoons though, I noticed a greater change. My ECT now doesn't go above 188F and my EOT is around 206F, maybe 208F briefly if I have to WOT pass someone camping in the left lane. These peak numbers are always quoted during/after the strenuous 90MPH cruise portion, everything always cools down once I get on the back roads with 65MPH average speeds. This brick, with these piston squirters, and these 3.92 rear gears, is a chore running at sustained speeds in this Texas heat.
Even more impressive was this morning's commute. This morning was a morning for assholes, myself included. Everyone felt the need to be extremely aggressive, myself included, and I was driving the wheels off of this thing, doing things I wouldn't do in my much newer and much more advanced-handling mustang. I am talking several WOT stints of winding out several gears, well over a dozen in a short period of time with no cool down times and the ECT never got above 190F and even then it was only momentarily, the EOT was running 208-212F and peaked momentarily at 216F, which for how I was driving, is a testament to the setup of these heat exchangers. Hell even the 8HP70's fluid reached 135F, which runs full time to the standard 6 speed condenser cooler, which usually doesn't ever get above 120F.
Anyhow, this is another testimony for how great the honeycomb grille flows over the more restrictive sport grille.
I too have a 3.92 on a 2016 1500. My engine runs real hot when towing in the heat. My oil temps are up to 260 degree F. I have bought a Derale oil coller but have been warned it swill not do much and may leak. I really have no idea what to do. I may speak to a race car builder I know. If anyone has any suggestions, please let me know.
1SLwLS1
1SLwLS1
Are you using a Derale kit or just a Derale cooler? The cooler itself will be fine, all of their fittings and hoses will probably be a restriction. What size is the cooler? It will do something but maybe not as much as you like if it is too small.
shortman
*******, GA
Very interesting issue.... I just read/skimmed the entire thread....
OP... Just curious.... Why did you choose to run the thicker oil? The 6.4 calls for 0w-20 because of the closer tolerances of the forged internals.... Is it possible the thicker oil could cause additional heat?
1SLwLS1
1SLwLS1
The 6.4 calls for 0w-40. I am in Texas and we do not experience much cooler weather so I bumped up to 5w-40.
