4.56 Ring & Pinion
Status
Not open for further replies.
Saltillo Express
4.56 Ring & Pinion for Ram 9.25ZF rear end. Including Timkin Bearings that came with it, you can use em or pitch em. Gear is a US Gear. You will need to get your own install kit, shims, etc. I ran the gear for about 600 miles. A little steeper than I wanted for stock height wheels. A great gear for off the line performance or oversized tires. It was absolutely awesome around town. Sale is final, no returns. $200 firm shipped to the lower 48.
martinuresti
Dallas, Texas
Noob at gears and such.
How can I tell what rear end I have? I have a 2014 Lonestar (Big Horn) with the 3.21's. I'm going with 37's and I figured I'd need these type of gears. What all would I essentially need in order to make these work on my truck? Sorry for all the questions lol
With a 2014, you have the 9.25ZF rear axle. RAM has been using these axles since about 2011
Another thing to consider will be changing the front​ the axle gearing, IIRC going to lower gearing, 3.92(factory) is available. Anything lower and your looking at doing a custom front carrier swap from a earlier year truck.
I'm guessing the OP has a 2WD truck
Status
