4 inch lift, how high is your ram?
BOWERSFJ
Uniontown OH
Yes I’m not too bright I know. This is my first time wanting this done.
I may not be very bright but at least I had the brains to talk with the experts on this forum before I paying out this kind of scratch.
Please just don’t go back to that shop ..... Price the lift, wheels, and tires you want online, and multiply by 1.5 .... That should be close to what you should pay total ....
kirwinjd
Great. Thanks so much for the advice. Definitely won’t
Craigger
Norfolk VA
5.7L V8
Back before my lift I had a 3" front and 2" rear spacer. Stock 33s it was like 40 1/4 front fender and 42 rear if I remember correctly
Sent from my KYOCERA-E6920 using Tapatalk
Where did you buy your 2" rear spacers from? I need to do the same thing but heard if you dont buy really good ones it can lead to snapped posts. Thanks
Ohio5pt7
Ohio
Motofob put 50k on them no issues
JB1
Houston, Texas
Thanks I’d like to but I ain’t Bank of America lol
You might want to select your tires/wheels etc and decide on a budget you can live with then select a lift to fit that budget
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
This the quote I got.
that’s not far off for that kit. That’s top of the line. There is less expensive options out there but $5k for a no spacer lift is the going rate
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
@kirwinjd Kit retails at $4300 install is $700 you are not beating that price. $1,000 is the standard install 10 hours of labors and an alignment. At my shop we normally do the zone lift with the bds coil overs and save a few dollars. If you buy wheels and tires at the same time we can shave a little more off. You don’t want the most expensive shop around but you definitely don’t want the cheapest. You want a shop that only does suspension work. The everyday mechanic shops end up doing more harm not torquing anything. There are plenty of install videos on you tube showing guys zipping everything back together in the air with air tools. Exactly how you don’t want your suspension installed.
olyelr
Kewadin MI
Yea thats not a bad price for that kit, and their labor rate looks spot on. If you are satisfied with the current ride of your truck and are looking to save some cash, get the 6” spacer kit instead which will reuse the current struts up front. It will save you a couple grand.
olyelr
Kewadin MI
Those coilovers are a $2000 upgrade? The rest of the kit is the same as the 6” spacer kit, correct?
kirwinjd
Sounds like a good idea. Thanks
What is a good tire for a 6” lift?
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
All depends on the look you’re going for, what rear spring option you choose (3” or 5”) etc.
Ohio5pt7
Ohio
6' with a 35x12.5 on a 24x14. My speedo is recalibrated to a 33.5 tire because of the stretch. Personally I don't like thw lip exposed that much if I stick with 35s next set will be a minimum of 13.5 wide. You can also check out customoffsets.com 20200711_131550.jpg
BJSwizzle
Edmonton Alberta Canada
2019 1500 Sport
5.7L
I originally had a front 2.5” levelling kit on, but did not like how it settled, the front always looked higher to me, so I decided to put in a 4” ready lift kit, I figured a 6” would be too high to fit in certain parking structures, I’m happy with my decision!
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
BJSwizzle
2019 1500 Sport
5.7L
Yup, rescued a sport hood from the wreckers, had some hail damage, the coating filled in the imperfections, had it colour matched
