1 Ram Guy
- Sep 23, 2016
- 22
- 2
- Location
- Southern Minnesota
- 2016 4X4 Big Horn Crew Cab
- 5.7 Hemi
I have a 2016 Ram Big Horn Crew Cab 4X4 with Hemi and 3.92 gears with limited slip rear differential. My problem is that my truck will back-up (in 4X4) my steep concrete driveway with a dusting of snow on it-BUT- when I put the truck in "park" the 4X4 disengages and the truck slides down the driveway with only the rear tires sliding. I took it to my dealer and the shop foreman said that is normal (because he took a new truck off the lot and it would do the same as mine while testing on the hoist). The first time it happened I thought it was because I had it in "4 wheel auto". So I recently tried it in "4 wheel lock" with no change, so I tried it in "4 wheel Low lock", and it is still the same. Is this normal? What can I do to correct this?
I'm not positive that is from putting it in park or from opening the door to get out of the truck, (with engine running) but about the time I close the door and start walking away- the truck slides away!!
Do all brand trucks operate this way?
Could some reprograming fix this?
Thanks for any info on this.
