4BT Silverado
SmokedRam
Zephyrhills, Florida
Sweet...there is a place down here called "Twisted Metal Offroad" who specialize in Cummins swaps. They have done Hummers, Jeeps...all kinds of different things.
schroederMP
Indiana
Cummins
I need to do this to my car...with a hood stack
GhostRam94
Hunstville, Texas
2009 Laramie CC
Through some proper badges and body kits to make it look like a dodge and Id rock that chebby all day long
Stangshcky12
Oshkosh, WI
5.9 Cummins
Eh not from my experience
I helped a buddy put one in a jeep, I wouldn't put it anything bigger then a mid size truck
It weighed in around 3500 lbs so that truck has a good 1500lbs on it i'd guess
the motor weighs about as much as a big block Chevy and only run about 120-140 hp and 350 ft-lb stock and dont like to be pushed much more then 200 hp
Only thig I would think that trucks good for is fuel mileage
Stroked
Beloit, Kansas
That's awesome. :drool:
I know I've seen several 4bt's putting out a helluva lot more HP than 200. No where near the capabilities of a 5.9, but still not too shabby.
Stangshcky12
Oshkosh, WI
5.9 Cummins
I haven't looked into them since last summer but I only saw 2 or 3 with numbers higher then 250 hp and these guys were pushing 70-80psi of boost and egts of 1800-2000 degrees
Anything more 220-240 that start overheating
To get anymore then then you need a ridiculous full pump and a cooling system to match
They can be pushed to 350-400 hp (with nitrous/methanol injection)
I don't think I've seen a fuel only dyno over 250-260 hp
Of course like anything, with enough money it could be done
reddot
Wolf Point, MT
5.9 cummins
someone made a 4bt awd ranger drag truck. twin turbos and a supercharger. pushed well past 700hp if I recall right.
WhiteExpress
Midland, TX
I wanted to swap a 4BT into my '00 Ram. I think it would have been perfect. Pull up hills like a freight train, and just honker down and cruise the rest of the time.
I think the 4BT is the ideal 1/2 ton truck motor personally.
Run that puppy on B90 all day long!
reddot
Wolf Point, MT
5.9 cummins
yeah if they had a OEM option for a 1500 4bt I would get one 2wd rcsb!
Stroked
Beloit, Kansas
I had every intention of putting one in my '84 K20, but changed my mind when I discovered how poorly balanced they are. The guys that have ran them for a while have problems with windshields cracking and other things.
Viper21700
Woodbridge VA
98 CTD 12 Valve- Half the valves, twice the fun
You can actually get them balanced out fairly easily. Stock they vibrate like a crappy chainsaw, but Ive seen a few worked on that run smooth as silk (or as smooth as a cummins will run at idle)
Fpye
