4th Gen Front Bumpers (what fits/doesn't)?
Jeepwalker
WI
2012 Reg Cab, 4x4
I forgot what fits or doesn't fit for both 1500's and 2500's. And are the brackets all the same or different between 2012/'13's? Mine's a 2012, with black steel bumper. I've seen a few chrome take-off's. Will 2013 and newer bumpers also fit (with the old brackets ..or '13 brackets)? As I recall F bumpers were 2012 and below. I'm not worried about the fog lights, I could always add them if that was the only difference.
I did a few searches, couldn't find those old threads. Can you guys please remind me?
Thanks
without measuring, the difference that i see between the 2009 - 2012 Dodge Ram 1500
& the
2013 - 2018 Ram 1500
is the Grille & upper valance shape
2009 - 2012 look at the lower corners of the grille & the shape of the grille emblem
as well as the horizontal fog lights
2013 -2018, cut off lower corners & cut off emblem
vertical fog lights
Heavy duty Ram changed some features a year later (2014)
Although the fog lights remained Horizontal
2500 bumpers wont fit 1500's. You looking for oem type stuff or ranch hand? You see the headlights, on the 2500 it is straight across and not raised off bumper line. see the bumper line on the top of the bumper, 2500 straight across...
On 1500's you see bottom of the headlights..
On 1500s this is a Upper Valance, it fits between the front bumper & the grille
2016 Ram stock from factory
J
Jeepwalker
WI
2012 Reg Cab, 4x4
Thanks for the info guys. Reason I ask is there's a guy locally who's got a fairly new stock chrome bumper, he's adamant 1500 bumper's will fit 2009-2014. All my research shows it's 2009-2012 or '13 on up. But I can't remember if the bumper brackets are different or what the differences are. Any more details what the specific differences are.
I have a 2013 - 2018 Front Chrome Bumper
It is the one with the dealer plate up above
serial number sticker
This post might answer all of your questions
J
Jeepwalker
WI
2012 Reg Cab, 4x4
I think I found most of my answers about key differences between 2012 and 2013 front bumpers.
1) Shape: 2013 and up have a 'dip' on the top middle. The filler panel dips down and the bumper is stamped different along the top front. 2012 and below steel bumpers are straight across (flat).
2) Flange: 2009-2012's have a 1" vertical flange along the top of the stock steel bumper, which the bumper filler panel bolts to. The 2013's and up F bumpers don't have that flange.
3) Backing panel: I read on another post the filler panel which mounts behind the F bumper is a different from 12-13. Shape is different.
4) Bumper Brackets?? - I believe I read there might be differences in the bumper brackets ....but I can't provide any details.
A guy could buy the parts to swap a '13 bumper/filler/grille, etc and some guys have done that. And that looks good. But then you're talking about a lot more work, not just a bumper replacement. Also, the 2013 on up grille's attach differently than the 2012 and below, so a guy would have to fab up metal brackets to make it 'work' (which I could do). But I'm not looking to do a 2013 front end swap.
Ironically, that local guy selling the bumper I mentioned above, looks to be the right one for my truck, other than I would need to add fog lights.
If anyone has more info on differences, please add below.
ilovemyramlaremie
Moravia NY
I just did a complete bumper swap from a 2010 Ram laremie 2 pice bumper to a 2015 Ram tradesman one piece bumper. It’s on this section
blue beauty
North carolina
does anyone know if the new style of front bumper (2021,2022) will fit and 2012?...I rly like the new style but don't kno if it would fit
It's possible to swap a new style 2500/3500 from end onto a Gen4 truck.
95Ppump
I'm wanting to put a 2022 bumper on my 1995, does anyone happen to have the plans to build the brackets?
OTownRam
