A true crock of p_oo-p!!!
The dealership is lazy and complacent, and no fluid is ever "lifetime"
It is very important, especially if you plan on keeping your rig, to change the transmission fluid and filter.
If you're handy, it's really not a difficult thing to undertake yourself.
If not, then ensure you get the correct parts and take it to a very trusted technician to do it.
Only use MOPAR or Valvoline MaxLife trans fluid, and only MOPAR filter kit, or the upgrade PPE transmission pan with their replaceable filters.
This would also be a very good opportunity for you to install the
@caulk04 transmission cooler bypass valve upgrade as well.
This mod is 100% trusted and supported by the collective here on our forum. I myself have purchased about 8 of them so far for my and family/friends vehicles.
This upgrade drops the transmission temps by up to 30deg/c, and the engine temps by 3 to 5 deg/c as well.
However, one MUST follow the prescribed fluid/filter change procedure to a "T", period!!!
This is crucial to ensuing the fluid level is 100% correct.
These transmissions DO NOT like it when they aren't filled properly
