5.9 Block Heater
brushman
5,9 cummins HO
I have a 2005 2500 with cummins 5.9. I cannot locate the block heater? Do they come with one from the factory normally? Thanks
MegaCab1Ton
Des Moines, Iowa
Cummins 5.9
I'm no expert but I read somewhere a couple weeks ago that they all come with the heater element in the block but the power cord may not be on it. I'm sure a quick google search on the subject can probably find your answer.
LETHAL GTS
Winnipeg MB
Look at the frost plugs along the side of the block.
They are installed into one of those. If you don't see anything but frost plugs, you don't have one.
