5 Lugs: are they created equal?
tcware
Bowmansville
My 2011 Big Horn needs new wheels. It's 5 Lugs, 20 inch. The 5th gen Classics are also 5 Lug, 20 inches. Are they compatible? or is it a sensor issue?
The rims are compatible but the tire pressure sensors are different. If your getting new tires, have new sensors installed at the same time.
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
Technically they aren't called 5th gen Classics, they're called Ram 1500 Classics. The only thing they have in common with 5th gens is model year.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
2011 Ram 1500
Center Bore / Hub Bore: 77.8 mm
Bolt Pattern (PCD): 5x139.7 (5x5.5)
Thread Size: 9/16" - 18 UNF
Wheel Tightening Torque: 160 - 200 Nm
2020 Ram 1500 Classic 5.7L​
Center Bore (DIA): 77.8 mm
PCD: 5x139.7
Thread Size: M14 x 1.5
jws123
nj
Can confirm if the newer wheels have the sensors they will not read if you care about them you will need new ones for 2011 I had newer set on my 2011 from a 2015.
GTyankee
3.0 ecodiesel
Right now, i can't recall what Mhz my 2009 had for TPMS, so i Googled it
433 mhz
2009 - 2010 Dodge Ram TPMS Sensor Schrader 56029359AB 433 mhz.
2011 - 2013 Dodge RAM 1500/2500/3500 TPMS Sensor Schrader 56029398AA 433MHz​
You will find some 2011 Dodge Rams with 315 Mhz
i believe that many 3rd Generation Dodge Rams have the 315 MHZ TPMS
TPMS Sensor, 433MHz Tire Pressure Monitor System for 2014-2021 Dodge RAM/Jeep Cherokee Replaces# 68249197AA.
By the way, Many Rams with Keyless Entry, also work on 433 Mhz
jagman_xjs
Clarksville IN
2003 2011 2019 2023
5.7 Hemi(s)
I buy and sell 4th gen wheels. There IS a difference in RAM wheels some crack way easier than others. Most Gen 4 wheels I have seen no problems with other than when they have hit a big pothole or curb. However the thinner spoke Dodge wheels and RAM Sport wheels are the ones I have been seeing them crack. The bigger spoke wheels I rarely see unless as stated above. I only sell 20s so I know little to nothing about 17s rims.
